Posted by gene bender on January 15, 2014 at 18:48:04 from (207.177.56.213):
In Reply to: super a gear box posted by farmall4856 on January 15, 2014 at 15:23:10:
I have done several. Easy way is to remove the axle and wheels. Then you can remove the bottom half of the steering sector. You also want to remove the steering wheel and then the large nut on the steering sector ,screw the steering shaft out thru that hole. To remove the bottom half of the sector the drag link will need to slide off the main shaft as you drop the bottom. Then you can replace seals,bushings and bearings and gaskets. Fill with 90-150 when done and it will work like new again.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
