Hardest job is to loosen the driveshaft bolts. They are tapered and hard to loosen. This is how I have "easily" loosened them: 1. Turn shaft(clutch depressed or rotate engine) so bolt is on the bottom, 2. Take a combination wrench and place box end on the bolt head, 3. Remove nut & lock washer with second wrench or socket, 4. Take a larger combination wrench and lock the box end into the open jaw of the first wrench so you have (in effect) a longer wrench. ( this will test the lifetime warranty of the tool!), 5. Place transmission in 1st or reverse (clutch pedal released so engine resists turning) and lock the brakes. 6. Apply firm pressure to turn the tapered bolt; when it "snaps" the bolt can be removed. You may need a pipe wrench to help hold the shaft &/or coupler from turning. Remove the two bolts on the shaft first and the coupler bolts last. Heat or hammers, etc. may do the job but simply turning the bolt works so much easier & faster.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
