Posted by Tom Fleming on December 16, 2013 at 16:09:51 from (173.233.18.197):
In Reply to: '42 H Just Won't Start posted by Farmer Matt on December 16, 2013 at 07:30:46:
ok, some good advice has already been posted here. An engine needs 4 things to run: fuel, air, spark, compression
The only thing I am going to do is put it in order like a check list:
1.) Make sure valves are set at correct, COLD lash.
2.) Set timing manually. As already indicated, get #1 TDC for the compression stroke. As indicated, install distributor firing at #1.
3.) Make sure plugs and points are properly gapped.
4.) Wires should be copper core, with bright, clean connections. Firing order 1,3,4,2, going clockwise from #1 post which is at approximately 2 o'clock on the cap.
5.) Turn on fuel, and make sure carb is getting plenty of fuel flow.
6.) Iidle air adjustment should be closed tight, then out 1 1/2 turns. Main jet, same, bottom out then at least 2 to 3 turns out.
7.) Air cleaner should be clear and clean. Fresh oil.
8.) Open and consume beverage of your choice, review and recheck previous 7 steps.
7.) start it. Consume 2nd beverage whiling enjoying the sound of your Grandpa's running tractor.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
