You can usually purchase a tractor with a loader for less cost than buying them seperately. Most loader tractors already have fluid ballast in the rear tires and/or extra wheel weights. Often loader tractors can be purchased with tire chains and a heat houser if you ask.
An H and a C are close to the same horsepower, but a bare H would have close to 1000 pounds more weight than a bare C, more gear selections and a longer wheel base, all will help a lot with a loader. An H with a loader should be able to push and lift nearly twice as much as a C with a loader. Similar to comparing a John Deere B to an MT or a J.I. Case SC to a VAC.
Farmall H tractors are useful, plentiful and inexpensive. If you can find a Farmall SH, SM, 300, 350, 400, 450, Oliver 77, 88, or Case 400 for not much more money I would jump at it though. The live hydraulics and faster gears will be more useful.
A loader makes a tractor longer, clumsier and steer harder, especially with a wide snow bucket. If you don't want to have two tractors, consider getting a loader that is easy to remove and install so you can easily drop the loader when you don't want it. A Deere #45 loader is one that is easy to remove, others loaders may be similar.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
