Hi Rober, my brother uses a tank heater on his 684.
See photo I found on internet of 574 with tank heater mounted behind front motor mount. Requires a tank heater some heater hose, pipe clamps and pipe nipples. There are two plugs to removed and replaced by pipe nipples, one on the water manifold at front top right of engine and the engine block drain just above the starter on left side of the engine. The cold water line is connected to bottom of tank heater and the nipple in the block drain above the starter. The hot water line is connected to the top of tank heater and heater hose is routed around behind fan and to the nipple installed in the water manifold.
Note the tank heater has to be mounted like the one in the photo with the top of the tank below the level of the pipe nipple in the block drain. This is required to allow the hot water to rise and circulate thru the block.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
