I don't remember just where I got the information. Might have been at service training from one of the older IH "block men" like they called them back then. But anyway, the explanation is for safety first off and second, the magneto's advance was closer to 40 degrees so setting it 5 after gave you the recommended 35 degree advance. As you well know, a few degrees one way or the other on those old low comp engines didn't amount to squat. When we put power packs in , well, things got to be fussier. One other thing that has never been mentioned is if crankshaft has been ground, sometimes the grinder cheats a little to get the best overall journal and that can change the top dead center a bit. The local machine shop explained that to me one day as I had found an 806 diesel that the flywheel tdc mark was off 8 degrees and it had been reground previously. I used a dial indicator on piston when head was off to determine that. That really threw me as I hadn't run into that before or maybe just never checked the marks that close. I would not want to hand crank an engine timed to fire at top dead center. It could go either direction really easy.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
