Re: start on farmall m
Posted by rvirgil_KS on December 02, 2013 at 14:48:12 from (192.208.173.110):
In Reply to: Re: start on farmall m posted by butch49 on December 02, 2013 at 13:20:38:
With negative ground, the negative post on coil should go to distributor, positive post to ignition switch via resistor if used.
With switch on, approximate voltages at the coil should be:
Input (switch side) without resistor 12 volts, with resistor 12 volts points open, 6 volts points closed.
Output (distributor side) 12 volts points open, zero volts points closed
Sounds like the coil wires may not have been switched when alternator conversion was done.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
