Steve706, It's a relatively simple system, so it won't be too hard for you to figure out. Seeing as you say you have NO power to anything, it rules out all the minor stuff. If you have a meter it will be a bit more informative, but even a 12V bulb on pigtails will give you solid clues.
First, check the battery at the terminals - a bulb should glow brightly, or a meter show at least 12.6V (half that if it's a 6V system). Next, move just the grounded test lead to some point on the chassis - it should show the same as on the battery itself. If it doesn't, you have a bad ground connection between the battery and chassis. If it shows good, then move the "high" side test wire to the battery stud of the starter. If it doesn't show good, you've a bad connection on that side of the battery. Not that this next step applies to the 100, but with any tractor that starts from the key switch (rather than a starter rod), if you have power at the starter stud and chassis but nothing beyond (like lights) the probable fault is in the "fuseable link" - the smaller, usually 10 AWG wire that goes from the starter stud to the ammeter and the rest of the electrical stuff on the tractor. Some of them are actually fused! Most from the 40's to 60's aren't.
Yes, battery connections can give out 'just like that', and usually, it's the positive terminal that needs the cleanup, be that the grounded or high side of the system. If the battery clamps have been replaced, there is a chance that the wire clamps have a bad connection.
Hope that helps. If not, let me know and I can walk you through a more through set of tests.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
