Posted by Janicholson on October 29, 2013 at 21:12:28 from (74.60.94.18):
In Reply to: 6 to 12 conv. posted by rcarraway on October 29, 2013 at 20:30:33:
A Hitachi 14231 alternator fits well, and is more tidy than a Delco. The wiring is the same as the delco (I would not use a one wire system) The #5 diagram in the link shows the diagram for a Faemall M. It needs to have a couple of modifications and an explanation. The Delco Shown has two small terminals. marked 1 and 2. The #1 terminal is L on the Hitachi. The #2 is equal to the S terminal. Use insulated 1/4" female spade terminals to avoid the connectors touching in the alternator. You will need to reverse the leads on the amp meter. You will reverse the leads on the coil to match the diagram. You will need to add a ballast resistor (Chevy 64 V8 will do fine) as shown in the diagram ubless you use a 12 volt coil with no resistor needed. The diode can be a little thin in the wires. Putting it into the system and soldering the leads so that it forms a Z makes the leads double back on the diode and when taped up makes it stiff and less prone to breaking. (make sure the Band end of the diode (elecrtically) faces the alternator. All bulbs need to be replaced with 12volt. Using LED headlights makes real light to drive by! and last hundreds of times longer than regular bulbs. Search the net for the correct base and shape. All other connections remain the same. The starter and relay will work fine and spin correctly with reversed battery connections (negative ground) Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
