What screen are you cleaning. The filter bypass screen or the lube pump pickup screen. The one that will give you trouble is the screen on the lube pump inside the transmission. If your oil is getting hot it is because you are running under high pressure and has nothing to do with air. The system is self bleeding except for the brakes as they are a dead end. You need to put a gauge in to see what pressure you are running when all valves are in neutral. It should only be regulated pressure which is less than 300 psi at the pump discharge .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
