Posted by Fudd on October 24, 2013 at 14:52:34 from (63.228.76.70):
I removed the voltage regulator and found no markings as to what the ground should be. The battery was installed with the neg. to ground. I have unhooked everything in the charging system and the ignition system and still get a 3 volt discharge. I reversed the battery and installed it pos. ground, polarized the VR and started it up and the amp. meter discharged. I then changed everything back and polarized the VR again and started the tractor and the amp. meter showed a charge and it was 9 volts on my meter. I unhooked the pos. cable and I then had a 5 volt drain. So much for progress. Is the light switch on the left side of the instrument panel? There is a switch there that is broken off and a sheet metal screw has been screwed into it. None of the lights come on when I hook the battery up no matter where the switch is. I could not get the throttle lever off to pull the instrument panel so maybe tomorrow with some PB Blaster. I also need to know which hydraulic fluid it takes as it is bone dry. I think I will be bald before I get this one figured out. Thanks
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
