Posted by Fudd on October 22, 2013 at 18:52:23 from (63.228.76.70):
I"m working on a friends 240 that drains the battery. Today I 1)Disconnected the coil, 2)disconnected the wires from the small post on the starter relay and the link between the relay and the starter, 3)Disconnected the generator wires. The voltage regulator and generator look fairly new and after removing the VR cover I could see the points were both open. I think I will disconnect the voltage regulator just to make sure that isn"t it. The battery shows 6 volts and with the positive cable removed I get 3 volts between it and the battery post. Is this a positive or negative ground system? When I hook the cable to the battery, the ammeter does not move. Right now it is neg. ground. If I remove the neg. cable from the frame, the drain goes away. Next step is pull up the instrument panel and check the wires under there. What hydraulic oil does this take, it"s low. Wiring diagram? TIA
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
