Posted by John T on October 21, 2013 at 06:20:17 from (67.78.33.134):
In Reply to: Cub points problem posted by beargap on October 21, 2013 at 03:44:21:
Typical causes are excess points current and/or a bad condenser.
When it was converted to 12 volts was the old 6 volt coil still used??? and if so was an external series voltage dropping (12 down to 6) ballast resistor added???? If its still a 6 volt coil unballasted it will overheat and the points burn up quickly.
Put a voltmeter on the coils input (NOT the terminal to distributor) and turn ign on and when points are closed read the voltage?? If its a 6 volt coil you need 5 to 7 volts or so (because a proper ballast would drop the other 6 volts). If it was replaced with a full true 12 volt rated coil (NO ballast) then Id expect like 12 volts.
If the coil is correct try a new condenser. If its still a 6 volt coil see how hot it runs???
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
