Well first ya have to figure out WHY , So lets start with does the rest of the hyd. system work??? Will the three point or fast hitch rise and lower ?? IF not then you have a major problem as the input shaft for the PTO just went south and to repair you will need to split the tractor at the bellhousing and replace the input shaft bearing and seals and a new clutch . IF the rear hitch still works then your problem is in the MCV area (1) you lost prime due to a plugged filter or sucking air or your low on Hdy fluid (2) Does your oil lite work ??? , is it blinking at you ??? IF it is not working when you turn the key on then fix it ( bad bulb ?? ) Could be that the flow divider has stuck or the pressure reg. valve ?? Do you have a BOOK ?? if not get one and read. Things to do now is check fluid level , change hyd. filter and gskt. top off hyd. oil , Next run tractor at 1800-2000 RPM and turn steering wheel to left to see if it will pick up prime IF the rear hitch is working . Also you can remove the plug on the back side of the MCV that takes a 9/16ths wrench and start the tractor at ideal and be ready to shut if off FAST because if it is air locked once she picks up prime it will shoot a LOT of oil out real fast . then replace the plug and you should be good to go .
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
