I rather have the magneto working if possible the reason being it bugs the heck out of me seeing the magneto coil cover setting there with no coil wire hooked up to it...and I think the magneto is a more efficient ignition than a coil...
Repairs I have done so far...
Removed slack from steering down to 1/2 inch from 4 inches.
Repaired Belly pump oil leak.
Repaired oil leak at back of engine, Thought it was rear main seal but pulled pan and rear oil pan plate and checked the rear main seal and was not leaking some one did not seal the rear plate properly and left it loose resealed and tighten and no more leak.
Repair charging system (Alternator) and wiring...
Overhauled carburetor.
Cleaned bottom of oil pan and bottom of oil filer housing and oil pickup screen, change oil and filter. 50 psi at idle after the clean up.(little high but I can leave with it).Was 20 psi before cleaning. Engine is very clean no crud at all...
And some other little repairs here and there...
One rear tire is weak but got an extra wheel and tire with the tractor but the wheel is wider looks like an inch or so but the tire is the same size need to remount it on the original wheel.
Almost done thanks to everyone on this forum for all the help...Raner...
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
