Like others have siad , might be restricked fuel flow , But have you checked the manifold bolts to see if they are tight ?? , have you checked the heat riser to make sure that it is working ???, When was the last time you did a complet tune up and checked ing. timing ???, when was the last time you set the valves??, are you running 93 octane grade gas??? This is a modern 6 cylinder gas engine and it is a high RPM engine and requires the 93 octane Read in the org. operators manual on MIM, fuel requirement check ing. timing at full throttle for full advance . run only a C86 A/C spark plug or a 3116 Autolite. for plugs. There is no adjustment for fuel on the carb as when the key os turned on the solenoid should pull the pintel wide open off the main fuel jet . NOW if there is junk and grud in the carb then you may have a small problem .
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
