Posted by pete 23 on August 09, 2013 at 18:15:43 from (74.47.41.165):
In Reply to: Cranking Oil Pressure posted by PaulW_NJ on August 09, 2013 at 15:33:24:
I would start it and watch for oil at rockers. It won"t hurt a bit to run without any top oil for several minutes. Perfect circle used to recommend blocking the oil flow to head when checking for oil consumption through the valve guides and run it several miles to check it out. If you do not get oil, suspect the center stud for rocker arm shaft as it has a hole drilled part way through and then out the side of stud so if you put in upside down or substitute a different stud you will have no oil to rockers.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
