The clearance between the throwout bearing and the shaft is normal.
As others have said, the throwout bearing is fixed in place, and does not spin. The pressure plate fingers "scrub" on the bearing when you depress the clutch pedal.
If you can't get it into gear because it's grinding, the clutch isn't releasing. It doesn't take much for the disk to stick/rust to the flywheel or pressure plate, especially if the tractor hasn't run in 10 years.
Taking it apart you may see nothing obvious but it will likely be fine when you put it back together now.
Before you slide the tractor back together, adjust the height of the release fingers on the pressure plate. IIRC they should be adjusted at 1-1/4" from the main metal surface of the pressure plate to the surface on the fingers that scrubs on the throwout bearing.
After you do that adjust the pedal free play to factory spec. I think that's around 1" as well.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
