Posted by gene bender on August 07, 2013 at 09:33:24 from (67.55.226.10):
In Reply to: Super A rear main seal posted by Adrian Billheimer on August 07, 2013 at 08:35:54:
NO that seal is quite a piece of work. The flywheel will have to be removed then the seal thingy is bolted to the block and its in two pieces and uses felt for a seal they are two small pieces and are inserted into those two halves then bolted back up to the block. The felt has to be installed very careful. The small gaskets probably can only be purchased with an out of frame gasket set. If you are careful they could be used again with some thin sealer. Only time ive replaced is when i have had the crank reground but that is the procedure.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
