Not to hard, under the pump mark how the slot is positioned before removing it if needed to install back the same. Put a screwdriver or something in the drive slot to twist back and forth for the backlash using a dial indicator if you have. The gear and shaft passes through a adapter that is oval shaped to change the backlash. Has different holes you can spin it to. Oil seal is under the adapter. Been so long ago that I can't remember if the shaft has a o ring or seal on it also. Anyway the slotted shaft with gear and adapter will pull out and you can see what's needed. Just don't turn the engine and put the slot back the same direction. Think I remember a dimple or mark on one end of the slot. Not sure of my memory though. Last one I did everything was worn so much it took all the adapter would give to get the backlash to .006 I think it was.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
