The voltage regulator your SC now says it's been converted to 12 volts. Ground polarity now could be either way, depending on the whim of whoever did the conversion. (From the factory it was 6 volt, positive ground)
A couple ways to determine polarity:
1 - Check the voltage regulator. Some (not all) VR's are designed for only one polarity. So ground polarity MAY be marked on the cover.
2 - Drop in a good battery and connect it for POSITIVE ground. Now turn on the ignition or lights. If the ammeter deflects to the left (indicating discharge) it is wired positive ground. However if it deflects to the right it is negative ground.
Once you've determined the ground polarity and completed your wiring, good practice is to polarize the generator before the 1st start: With the battery installed and the engine stopped, briefly jumper the BAT and GEN terminals at the regulator. Soon as you've made contact your generator is polarized.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
