With early petroleum refining, there were components of the crude that did not like to distill out as gasoline (light aromatic hydrocarbons). Further it was not heavy enough to be diesel or engine oil. Because the processes we use today with catalytic cracking, and extreme refining technology, that intermediate liquid was more or less a byproduct that held much less value. It was full of ash, (and sulfur from many feed stocks) as well as a low octane rating. It was thick enough that it didn"t vaporize/atomize well unless it was heated to 100+ degrees. There was energy in it comparable to gasoline, but it could not stand compression without detonation, and thus required low compression engines. Low compression reduces expansion ratio, and thus efficiency goes down as well. It does burn, it will run a spark ignition engine, it was cheap (probably a dime a gallon at times) It condensed on cylinder walls and worked its way down past the rings leading to the necessity of draining a quart of oil out of the tractor each work day then refilling the pan with fresh engine oil to keep it from being diluted and ruining the bearings. But engine oil was also cheap. It is not Kero. It is much lighter, and dirtier. It is also not produced due to the improvement of refining, and if made would be way pricy and illegal due to pollution. Those tractors smoked as bad as an old diesel. I hope this helps. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
