Starting at the back of that shaft, I believe it has a flange that the rear bearing rests against, then you have the bearing and the gears and spacers stacked along the shaft until you get to the front bearing. Then the alignment joint goes on the outside with a capscrew into the end of the shaft. Make sure that capscrew is in place and tight.
If that is all OK, the outer race of the front bearing inserts into the housing from the front with a 2 piece retainer clamped onto both sides of the bearing. I don't see a way that assembly could be loose and allow the shaft to move back (probably forward though).
The only ways I see (other than the above mentioned capscrew) for the shaft to move back is if the front bearing itself has failed and is allowing the shaft to move or the shaft itself has some major failure.
It looks like the rear bearing supports the shaft but does none of the fore/aft positioning. Unless the shaft itself broke, it looks like your problem has to be at the front, all accessable at the input joint. Adding spacers would push the gears and rear bearing farther back.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
