$350 Cub - Need's a lot of help
Posted by Stan on November 24, 2000 at 16:37:56 from (12.87.64.4):
Tractor now runs, starts every time and idles very smoothly and quietly no smoke knocks or missing. If it was meant to be a stationary engine never put to load I’d paint it and be done with the restoration. I have other plans for it so I need more help please. Help with any or all of the following questions would be appreciated. 1. I did Bob M’s 12 volt conversion and the warning light never turns off. Everything seems wired right. Had the alternator tested at the auto parts store and it was putting out 15 volts. When I pull the on switch, amp needle deflects to - but never shows charge at any speed of the tractor. 2. . When I advance the throttle it accelerates nicely then as it starts to come up to speed I get what I’ll call a wobble sound from inside the engine. Not a metal to metal banging like something about to break. More like the crank shaft would be coming unseated a little and bouncing around. This may also be part of the problem in #1 (Maybe it’s not running fast enough to start the alternator.) 3. Clutch does not work at all. When I engage the clutch to try and put the tractor in gear the gears grind like I hadn’t pushed the clutch in at all. Left in neutral with the clutch out there is a steady knocking sound that increases or decreases with idle speed. 4. Coolant circulation. With the radiator cap off it looks like every now and then a small amount of fluid circulates. When I turned it off this afternoon the top hose was hot and soft but the bottom hose was cold and hard. I am beginning to understand why it sold for $350. Thanks again for any help. Stan
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
