You hydraulic system is staying on demand. In other words under pressure. First thing is look at the ends of your hydraulic valves. There is a flat on a stem to turn valve from double action to single action. Often times the roll pin gets broken or bent allowing stem to be turned too far. If all valves check ok, then you have a problem in the regulator valve block. It is the valve with four bolts on cover. Under cover is heavy spring so caution if you take it off. I use longer bolts in two corners. You will find a screwdriver slotted orfice with screen. It is probably plugged. You will need new gasket though if you take cover off nine times out of ten.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
