1. Time the governor to the carb. Disconnect the carburetor throttle rod clevis from the governor arm. Tractor off, set the throttle lever to full throttle. Adjust the length of the throttle rod by turning the clevis until the pin slips through easily with the carburetor throttle pulled wide open.
2. Adjust the reaction spring. Rev the tractor from idle to full. It should snap right to, with no "bounce" to the RPM. If it bounces, you need to remove the acorn nut from the bottom of the governor, loosen the lock nut, and turn the screw in 1/8 to 1/4 turn at a time until the engine revs up to full RPM with one RPM bounce at most. If the engine surges at full throttle, you need to turn this screw OUT 1/8 to 1/4 turn at a time until you find a happy medium.
3. Adjust the high idle RPM. This is the screw on the top of the governor. Out is more RPMs. In is less RPMs. It should run at, I think, 1600RPM wide open with no load.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
