The hot post on the starter will have continuity to ground through the starter. The internal resistance of the starter is very low so it would appear to be almost a dead short. That is why the current draw is so high when voltage is applied to the starter cable. This continuity should exist all the way to the starter side if the starter switch. The other side of the starter switch back to the battery should not have continuity to ground unless there is another switch left on. If either the ignition switch or the light switch were on they would provide a path to ground.
Instead of checking continuity to ground it will be much easier to find your problem bu checking voltage drop under load across each part of the system. There should be no drop along a cable. A connection should have no more than .1 volt. A switch should have no more than .2 volts drop.
With all that you have done I would take a close look at the starter switch. Check the voltage drop across the two terminals while trying to crank the engine.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
