Posted by JimB2 on June 08, 2013 at 18:06:43 from (173.243.43.98):
In Reply to: 484 international posted by Lake on June 08, 2013 at 12:28:01:
Hi Lake, if I understand you correctly the HI/LO/REV lever is stuck in HI or LO, correct? Does it have the older style gear shift levers that are slide inside a slot?
This tractor has 2 transmissions, front one is speed transmission with gears 1 thru 4 and the range transmission(Hi/Lo/Rev) is in front of the diff. It would appear your range transmission is stuck in Hi or Lo. DO NOT FORCE the Hi/Lo/Rev shifter lever or you will snap off the shift lever that goes through the side of the transmission case. With engine off, chock the rear wheels, put speed transmission lever in between 2 and 3 then crawl under tractor and inspect range transmission lever mechanism for obstructions etc. You will see were mechanism connects to lever on side of transmission behind the hydraulic filter. Usually by some wiggling the mechanism and maybe a little prying you can free the shift lever.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
