Posted by pete 23 on June 06, 2013 at 10:38:05 from (74.32.230.205):
In Reply to: Farmall 656 Problems posted by Darren Mann on June 06, 2013 at 08:20:55:
As far as the brake I see no connection to pump replacement. If the pump sounds like it it sucking air like low fluid, plugged filter, I would guess one of two things. First, he put in a larger than original pump, second, he didn't get a new suction tube or damaged or misadjusted the seal on tube between pump and housing. Every body wants more oil flow and the 656 has all it can handle with stock pump unless you add the after market filter extension which helps. Now, I will a add, the gears take a wear pattern and the pump is driven off lower pto gear so that would (I assume have not been replaced. Lots of growly, noisey 656 tractors in the country. Also, there are different gears and pumps used as IH changed the gear ratio of pump, used a larger pump and slowed it down to reduce noise levels so things get kind of mixed up. A flow rater test on pump would show up any areation problem.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
