Posted by Dennis K (WA) on May 23, 2013 at 13:51:06 from (24.21.78.195):
I can't believe this system is whipping me but it is.
Farmall H, 6V positive ground, cutout relay and four position light switch.
Problem is no charge at low setting and cutout points do not close in low setting.
Normal output in hi, 10-15amps warm and as high as 18amp when cold. The third brush is moved up as far as it will go, 3 bar spacing on the commutator and against a stop on the end plate.
Checked grounds with ohm meter;
batt gr to dash screw or switch .1 -.2
batt gr to gen/cutout .4 -.6
F post on gen to switch .1 -.2
This has been this way since restored a few years ago and finally decided to deal with it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
