could be a couple of things from what you describe,are your hoses long enough to switch them from the bucket side to the loader side of the valves,if so change them and see if the problem moves to the bucket if so check the valve spool for proper travel,if travel is correct the valve could have internal damage which is uncommon,if switching valves has the same results as before then one or both lift cylinders is leaking internally a common problem,most of the time it is piston sealing rings damaged or worn out,but pistons will crack,cylinders will score ect. neighbor had the valves repaired on his mf industrial tractor it done the same thing yours is doing,the shop that built the loader spool up didn't machine the end groove back to it's original size was the problem
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
