If its a 12 volt system and has a true 12 volt coil YOU DO NOT USE A BALLAST OR THE SPARK WILL BE VERY WEAK.........(Toss the ballast)
A true 12 volt coil may be labeled "12 volt" orrrrrrrrrrrrr "12 volt NOT for use with ballast resistor" or "12 volt no ballast required"
A coil labeled "6 volts" or "12 volts for use with Ballast resistor" is in reality a 6 volt coil AND DOES NEED A BALLAST ON A 12 VOLT SYSTEM or it will overheat plus burn points quickly
Contrary to Billy Bob and Bubbas belief those coils DO NOTTTT I REPEAT NOTTTTTTTT HAVE A STAND ALONE DISCRETE BALLAST RESISTOR TUCKED AWAY SOMEWHERE INSIDE THE CAN.
Many typical old tractor 12 volt coils will have a LV primary resistance (measured between + and - terminals) of around 2.5 to under 4 ohms
If you have a 12 volt tractor and a 12 volt coil DO NOT USE A BALLAST OR THE SPARKS VERY WEAK
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
