Posted by pete 23 on April 14, 2013 at 11:04:54 from (74.47.40.242):
In Reply to: Farmall 560 pto posted by Busted on April 14, 2013 at 07:31:28:
Some drag is normal when cold. Should be able to adjust the rod to get good tension on brake and stop it. The over center clutch is latest style, early ones used planetery same as a 450 etc. You probably have worn keyways in operating shaft, worn overcenter mechanism inside or warped discs. You could also try changing the oil in unit to hy-tran as the old oil gets really thick and full of gunk. Only hold a short quart.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
