Posted by Nebraska Kirk on April 04, 2013 at 18:17:10 from (207.91.4.159):
In Reply to: Flywheel posted by slowfolk on April 04, 2013 at 06:04:18:
You will need a special tool to pull the flywheel. Unless you have the tools to pull and install the flywheel, I would first try to remove the bolts without pulling the flywheel. Pulling and installing the flywheel without the right tools is a pain, trust me, I have tried....
First of all, if you can't grip the broken bolt with a visegrip, try welding a nut to it. The heat from welding will help loosen the rust bond and then you can get a wrench on it. Heat the flywheel around the bolt with a torch, don't worry, the heat will not hurt the flywheel. Let it cool down some and then squirt some oil on the bolt, the heat will draw the oil into the threads.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
