If the conversion was a generator, and not an alternator, the polarity could be either negative ground or positive. If it is chargine and the battery voltage is at 14 or so volts it is OK grounded as is. If it is a generator, and not charging follow John Ts charging system procedure to set the system correctly. If it is an alternator it is 99.8 % negative ground. The coil should match the battery ground. Negative to distributor with negative ground.
Point gap is .020 on the high point of a distributor cam lobe. (turn engine by hand to get there)
A coil that says on its documentation that it needs no external resistor needs none. a coil that says "use with external resistor does need one. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
