Posted by pete 23 on April 01, 2013 at 10:08:33 from (74.47.40.242):
In Reply to: 706 trouble posted by BillyH71 on April 01, 2013 at 06:37:39:
If you have reverse and no forward speeds, I also think the high low shift rail has broke. Take the front wheel drive cover off left side , under clutch pedal. There you will see the reverse shift shaft and fork. Now look up inside to center of tractor top shaft. Move shift lever to high and low range. You should be able to see the range fork move back and forth. I bet it won't move. You don't need a split but you need to remove range trans cover, third arm link cover in rear and with a long arm you can reach that rail over top of differential and pull remainder out. New one can be installed from there also. I use stiff rubber or plastic hose and put rail in that and fish around until you hit the hole. Not an uncommon problem.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
