Posted by robgIN on March 26, 2013 at 15:30:28 from (70.224.35.32):
In Reply to: F20 timing. posted by Andrew Psencik on March 26, 2013 at 14:02:52:
sounds like you could have a carb problem too. Setting valves won't change your spark timing. Make sure your mag trips just after top dead center and then leave it alone. If you still have the problem, check valve lash and make sure none of them are sticking. If that doesn't eliminate it, make sure you have good plug wires and plugs and the cap is dry and not cracked. These old girls usually run really rich at idle, and if you lean the carb out to make it idle nice and smooth you will create the problem you describe, because every time you give it throttle or the governor does it is too lean and will cause a misfire. 3 1/2 turns out on the main jet is full rich and if you are much less than 2 you are probably too lean.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
