d282 has you on the right track.When you have the small plate off the clutch houseing their is a metal pointer that will point to the timeing marks on the flywheel when you turn it to the right spot which will be 8 degrees before top dead center.Ok on the side of the Roosa pump their is a small rectangal plate with two small screws holding it in place.Turn off fuel under tank take the small plate off and rubber gasket.You will see two scribe marks if you have it on No. 1 cylinder if you see one mark turn flywheel one more turn .Then both marks should line up when you are on 8 degree mark on flywheel.If not you have to rotate the whole pump that bolts to the front timeing cover .Three nuts bolt it to the cover loosen them some and turn whole pump to line up the marks when they line up tighten nuts.Then put everything back together.Then bleed pump if it has air in the sustem.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
