Posted by SuperABen on March 04, 2013 at 17:52:11 from (99.197.193.128):
Excuse the long post, but its all necessary to explain the problem!
I'm stumped on my 1948 Super A. About a week ago, the Super A had been running for about 20 minutes. I had it pushing in a John Deere M (no comments, now) that I was rebuilding. I stopped to kick the block from under the Deere, while the Super A was running about 3/4 throttle, with a snow blade, so there was load on the Touch Control. I got back on the A, and gave it a little throttle to push the Deere. From the three seconds I had gotten off and back on the Farmall, it suddenly had no power. As in nearly stalling while moving in first gear down a slope. I cut it off and replaced the D21 plugs with fresh. It ran much better, well enough to push in the Deere (which was quite a load) and even scurry down the road in high gear. It was still sputtering slightly, but it had power.
I pulled the Farmall out a day ago to (once again) move a tractor. It started immediately, I am hand cranking, but it had no power, once again. It died while I was trying to ease it into an area where I could work on it. It wouldn't start back up.
I tried to yesterday, cold, and all I got after four hand cranks (choke at 1/2 like always) was one loud bang in the muffler/manifold. Enough to loosen the muffler from the exhaust pipe! No backfire, but just one loud bang. The engine didn't even try to start.
I have checked timing. Everything is in tip top shape: fires #1 right at TDC. It can jump a 1/4 air gap at the plug. All the valves are free and adjusted properly.
The carburetor is spotless: good fuel flow, no junk in the lines, clean jets. Before this happened, the tractor would idle low enough to count the fan blades. It is a Zenith with no high speed adjustments. Compression is good, equal within 5 +/- across all four cylinders.
I also have good clean fuel, I drained the tank and refilled. All I still get is a loud bang.
So the question is, what does the problem seem to be? I have worked on quite a few engines (but not as many as the folks on this list) but I've never heard such a bang without a hot engine and too much choke!
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
