Posted by gene bender on February 09, 2013 at 03:08:25 from (67.55.226.151):
In Reply to: Brakes on Super A posted by nh8260 on February 08, 2013 at 21:07:22:
Remove the final drives and the bands are rite there. I remove the wheel then use a cherry picker to remove the final as its heavy. Important to have the chassis secured to keep it secure. You will want a cherry picker as the drivers whell has the cast center and is very heavy.If the seals are leaking the outer ones can be replaced by removing the drum and taking the diff shaft out thru by removing the plate on the final.. Mite also be a good time to replace the lube in the final by removing the bottom housing on the final then replace with 90wt thru the plug located at the bottom of the finaljust above the pan you removed to replace the lube.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
