Re: $350 Cub ...Starting ?
Posted by Bama Binder on November 06, 2000 at 06:47:02 from (206.5.110.15):
In Reply to: $350 Cub ...Starting ? posted by Stan on November 05, 2000 at 15:59:24:
Stan...I went through a lot of what you are going through when I was trying to get my Cub started after it had set up for several years (or so the owner said.) Some things to check that might save you some time. 1. Compression...the L head engines will often turn over fine but they will have stuck valves. No engine will run without compression...a decent tester will only cost $20 or so. If you don't have compression, don't go any farther until you solve that problem. 2. If the engine has sat for a long time, I would replace the following right off the bat: points, condensor, coil, rotor, rotor cap, plug wires, and plugs. It will be $60 well spent. Once you have a good spark and compression, look at the carb. 3. Carb. again, I have found it easier to just go ahead and re-build it to make sure it is sound rather than grind away trying to start the tractor with a bad carb. 4. Make absolutely sure you have the firing order right. Firing is 1-3-4-2...remember the cylinders are numbered 1-2-3-4 from the front. This will drive you crazy if it isn't right. Post specific problems as the arise, but your current problem is the same thing I had wrong and I had to go back to step 1 above and work my way back through before I could get mine started. Good luck...BB
Home
| Forums
Today's Featured Article -
Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
