Well the engine is sleeved. (dry sleeves) if you remove the existing sleeves thinner sleeves can be installed. It will not quite get to the SH dimension, but with higher compression domed pistons it will be more powerful than a stock SH. All other efforts will require boring out the cylinder block to larger diameters for bigger sleeves, or running with no sleeves. Putting a 350 engine block in it and using thinnest sleeves in that with high compression pistons (and its cam carb intake and distributor is about as powerful as you can get without compromising farm use or getting carried away with making a puller only. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
