Posted by jimb2 on December 30, 2012 at 19:31:28 from (174.114.182.155):
In Reply to: 424 axle oil leak posted by warren woodrow on December 29, 2012 at 17:16:17:
Hi Warren, The B-414,434,424 models were designed to use 90W gear lube in the transmission/differential. Some industrial models like 3444 used the transmission as a hydraulic reservoir with Hytran instead of 90W.
There is nothing wrong with using Hytran in the 424 transmission/differential but be prepared for some leaks. In fact Hytran is probably better for moisture conditions and operation in cold weather. I can remember using our 434 in -25F weather and you had to leave the transmission in the gear you wanted to use the next day. It would take a good half hour of running before you could shift gears easily.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
