Thanks for the advice. There is no resistor anymore since I now have a 12V coil, but I think I could do what you said about the diode anyway. It is about 25 to 30 degrees F here today. I did check the battery voltage and it seemed to be dropping into the 10.2-10.6 volt range when cranking for 2 seconds. When cranking for 5 or 6 seconds it dropped momentarily into the 9 range but then bounced back. I checked the terminals on the switch and have 12.4 on the ammeter side and 12.2 on the coil side when the switch is pulled. I do not know if that is normal or not. I put in new points, condenser, cap and rotor in the summer and I think I may replace the points and condenser again to see if that helps, and also I will get a better switch at NAPA. They had a $5 one and a $14 one and I got the cheap one at the time. Thank you very much. Zach
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
