Posted by pete 23 on December 26, 2012 at 11:54:48 from (74.32.229.189):
In Reply to: 1466 Draft Control posted by 61-4010 on December 26, 2012 at 11:31:28:
Works very similar to the Deere. That lower link contains a torsion bar which when pulling on the hitch points, it twists that torsion bar. It inturn is splined to a hollow shaft that has a sensing lever clamped to it and moves forward when hitch links are pulled to rear from load. This triggers the draft control valve to raise the hitch until draft load from implement stabilizes again and hitch stops moving. John Deere does same thing but that bar they use bends in the middle when load pulls on the ends. This inturn moves the sensing lever inside and also raises hitch. The IH also will leak from o-rings and requires draining, removing pto unit and getting the tube out to replace o-rings and maybe the bushings. We call them cheaters. Incidentally, new tractors use a pin with a resistor built in that senses the strain on pin, which changes the resistance which changes the voltage at controller which inturn raises hitch to again match the voltage previously seen.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
