Posted by The tractor vet on December 16, 2012 at 20:26:49 from (75.24.6.192):
In Reply to: Spliting a 706 posted by P T Farmer on December 16, 2012 at 18:58:37:
Your problem is more then likely the IDPTO sdealls and the PTo input and now are you ready for this , Ya may need a new clutch and pressure plate . It the splines on the PTo input are worn the hub on the pressure plate is also worn and this causes the shaft to wobble and take out the seals . so when ya replace the input shaft it is wise to also replace the bearing . When going back together i like to lock down the clutch fingers with small nuts to hold the pressure plate in the disengaged position then hang the pressure plate on the pto input then hang the disc on the transmission input shaft then slide it together , that way ya only have to get the inputshaft into the pilot bearing . Then ya bolt the clutch up to the flywheel from the inspection cover under the bell housing . And oh if your going to put a new clutch in it have the flywheel ground so everything is good .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
