Posted by The tractor vet on December 11, 2012 at 08:17:07 from (75.24.6.36):
In Reply to: # 2 valve is leaking posted by BigBob706 on December 11, 2012 at 07:30:21:
What do you mean when you say #2 valve is leaking?? is it missing on #2 or is it the fact that you see oil around the spark plug?? If it is missing then run a compression test , if it has a burnt valve on #2 then the head will have to come off and get a new valve installed and the rest ground . Now more then likely you will need new valve guides also . And when ya pull the head off now you can look and see how much ridge is in the cylinders , if you can catch your finger nail on the ridge then she is getting close to overhaul time . also while the head is off more then likely the head will need planed down to get it flat again. If it is a burnt valve then before you run it with a new valve job i would recommend that you start using a LOW ASH oil or you will become and old hand at doing valve jobs .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
