Posted by Zachary Hoyt on December 10, 2012 at 09:48:02 from (50.122.173.232):
In Reply to: Farmall B valve issue posted by Dave H (MI) on December 10, 2012 at 09:32:33:
My 300 had a stuck engine and a sticky exhaust valve when I got it, and I loosened up the valve well enough so that it popped back up after I hit it with a mallet. When I put it on the tractor the rocker arm pushed it down further than I had been with the mallet and it stuck again. I had just put a new head gasket in the tractor and did not want to pull the head and have to buy another gasket, so I was worried. I was able to pop the valve back up by using a flat pry bar on the underside of the valve spring retainer disk or whatever the big flat thing on top of the spring is called. I pried gently and I do not know if this was a good idea or not but it worked for me. Then I squirted ATF on the stem and turned the engine again, popped the valve up again and repeated for a while till it got so it didn't stick anymore. I put it together and have put probably 30 or 40 hours on it since then with no problems from the valves. Zach
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
