One item needing mention the dim position works by placing that wire wound resistor in series with the lights. It is powerful (able to dissipate) enough to work with the original headlights. If you put bright lights in it that draw even 20% more than the original lamps (about 7 amps or so) the resisor will glow then blow. One way to manage this is to use relays to control the lights. using the original switch would require your removal of the wire wound resistor to gain access to both the H (full output) terminal, and the D terminal (Dim) so that two different relays can power differing setups of lamps. If only bright is needed, disconnecting the resistor may be needed to avoid the glowing resistor. Jim
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
