Posted by Janicholson on November 03, 2012 at 15:04:31 from (96.24.99.126):
In Reply to: Belly pump on a Farmall posted by I don't know on November 03, 2012 at 14:41:57:
It is turning when ever the clutch is engaged (foot off pedal) this causes no problem for operation because it is open center hydraulics. Output goes to input with no restriction. It can be (and normally is operated with the lever/rod hooked on the rod stop at the hold position. (also no load on the system). If you feel the pump is slowing the engine when the rod is in that position (middle of rod stroke) then possibly the rod lever is not in its correct position on the pump valve. Less likely. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
